Saltar al contenido principal
Plasma tv with sound but no picture
I have a 65" Plasma Samsung TV that is only 3 years old and one day the screen just went black. There is sound and no cords were unplugged or loose but the picture was completely lost. There are indicator lights that it's working obviously since we still have sound but not sure where the picture disappeared to.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Jamie Russell what exact model is your TV?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I have a 43" plasma that had the same problem. After experimenting with several boards I found that the Y sustain board was bad. It cost less then $70.00 to replace. Again, check out the videos available on You Tube; I call it You Tube University. You will find videos relating to Samsung Plasma tv's. Since they are mo longer making plasma tv's you might want to hold on to the one you got. Believe me you can fix it for less than a new comparable set.
Fue útil esta respuesta?
Puntuación 2
Maybe the monitor is dead. It should be the time for you for buy a new one. I strongly not recommend to fix it because it's pretty hard if it's a superslim tv. most of the parts are soldered and not easy to take apart if you don't have any experience.
Puntuación -1
Añadir tu respuesta
Jamie Russell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 13,273
