ip6 dropped into water - no power at all
Hi friends -
Got a quality one for you. Was camping/tubing, dropped phone in water (sad) and all I was able to do was power it off. I didnt have tools with me (bad choice) until 24 hours later. Upon tearing the phone down, i removed all water, ultrasonic in alcohol bath, blew dry with compressed air, also heat dried with a hot air solder gun.
Put the logic in a known good donor and no go - No power at all. No sign of pc recognizing it either. Removed both lower shields (top and bottom near batt connector) and only see a little corosion on the edge of one chip. Ultrasonic cleaned again, no go.
What chips should i focus on that will allow power to the board? Id love to get the last 1500 pics back from the last 4 months....
Quick back story, Ive replaced 100+ lcds for friends and family, along with button cables and such. I have been 100% successful at water damaged phones when I was able to immediately remove the logic and let dry via techniques.
Es esta una buena pregunta?
@pquada you changed the lightning connector as well as the battery?
- de oldturkey03
@oldturkey03 - Yep, I used a known good donor (every other component) phone and popped this logic into it.
I did some further research and im thinking the iphone 6 charger ic may be the next step. I have successfully hot reworked one chip on an iphone 5 once before... However, a microscope would be needed to even want to try it again.
- de Paul
@pquada if you are thinking of U2 then it should still come on with a new battery. When you plug it in, what voltage do you get on the battery connector?
- de oldturkey03
@oldturkey03 - it doesnt turn on with battery either.
- de Paul
What is the voltage on the battery connector when you plug it in?
- de oldturkey03
