Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Boot loop after screen replacement
I have a friend's iPhone 5c and I changed the screen out for a replacement. I have done this several times on different phones with great results. This time the phone displayed a few lines of [NAND] dialogue, with the message "s_cxt_boot:88 sftl: error, unclean shutdown; adopted 863 spans". I found a blog saying to try replacing the frontcam/sensor flexcable, and the frontcam/sensor connector at the mainboard. I have replaced the first part, but cant find any instructions to do the latter. I have another phone that works, and could simply put the new screen on the other phone, but she has never done any sort of icloud backup and doesn't want to lose her stuff. Can anyone direct me?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi Jessica!
Yep, often error like these behave from an hardware error. This is the guide you need:
Reemplazo del cable del sensor y la cámara frontal del iPhone 5c
A test you can do before buy any replacement is to disconnect, in this case, the front camera / sensor flex and without close the phone, try to boot again.
If the problem still continue, try also to disassemble the shield that hold in place the display assemble cables.
Cross my fingers for you..
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I have replaced the front assembly. I need a guide for changing the connector on the mainboard.
- de
Añadir tu respuesta
Jessica Paradis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 130
