Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1624 Ver todo
After replacement of HD cable iFixit IF163-041-1 Mac doesn't turn on
Hi,
After replacement of HD cable iFixit IF163-041-1 Mac doesn't turn on, battery is empty and led light from charger doesn't light up, (I tried with 2 different chargers which work with other laptops), is it possible I damaged something during the replacement of the cable? and if so, where must I search?
Thanks in advance for your help !
Olivier
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Sadly, it does sound like you damaged something.
  • Why were you replacing the cable to start with?
  • Did you make sure the system was fully off before you started?
  • Did you use a plastic tool to disconnect the battery?
  • Did you have a hard time removing or putting back a part?
Hopefully, your answers here could lead us to what to look at. You may want to review again the process following this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I replaced the cable because the hard drive was working while I connected it as an external hard drive so I supposed it was the cable, I bought one, the system was off when I started, I didn't disconnect the battery (it's a special screw like à three branches star), I had a little trouble to fold the cable where it's attached with 2 screws
- de
Añadir tu respuesta
Rocq estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 222
