Saltar al contenido principal
La Coolpix S7000 se lanzó al mercado en 2015. La cámara tiene un zoom óptico gran angular de 20x, capacidades Wi-Fi y Near-Field-Communications (NFC).
Preguntas 20 Ver todo
Why has the camera locked up?
Camera is frozen. Screen is on (special effects/image mode) & lens extended. Camera will not turn off or respond to menu, playback or directional keys. What do I do to un-freeze /unlock it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Didn't see any answers, so I simply opened the battery/SD compartment and removed SD chip then battery. Put them right back in and everything is working again as it was before it locked up.
Fue útil esta respuesta?
Puntuación 7
11 comentarios:
I ended up trying this and it actually worked, thank you!
- de
yes, it worked! Thank you for sharing your idea.
- de
Thank you, that worked!
- de
Thanks a mill...it really worked
- de
This worked untill I try to zoom in and then it freezes again
- de
Mostrar 6 comentarios más
The best solution is using a SD Memory Card with great data transfer rate, like Sandisk Extreme Pro 95MB/s.
After change SD Memory, the camera has not been frozen or made this issue! Hope it help.
Puntuación 1
1 comentario:
My memory card is a SanDisk Extreme 64 GB with "45 MB/s" on the label. Is this really too slow for photographing my dogs in the Scene Sport mode of my Nikon CoolPIX P950? It may be time for a faster card.
- de
Añadir tu respuesta
Sarah Moles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 53
Todo El Tiempo: 10,550
