Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 193 Ver todo
How can I check if the power supply is broken.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
About 2 years ago, I found a way to test a G4 MDD's power supply, what you need to do, is make sure it is plugged in, and connected to the motherboard. Using a volt meter and a paperclip, check the connection between pin 14, and any ground (Pin 13 for example) by probing into the top of the connector. If it works, you should get +5 volts. you can use this photo for reference of the PMG5's pinout.
Fue útil esta respuesta?
Puntuación 5
3 comentarios:
Pin 1 and any ground may also work
- de
+ put the black lead of the multimeter in pin #1 and the red in #23. You should get +5 V
- de
Between you and Nic i tested mine, tells me my PS is good, now to figure out what else the issue is...
- de
I Have A Power Mac G5 (A1047) With Dual Prosessors and what i had to do was connect the 12V (Pin 23) to the Power On (Pin 14) and spun the fans perfectly. Try that as well.
--Nic
Puntuación 1
1 comentario:
Just did that, I have the model that the orig post mentions and was trying to figure which ports as 13 is empty. The image that chris posted was helpful as well!
- de
Añadir tu respuesta
Michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,407
