amber light on airport extreme
I get an amber light on airport extreme base station
Es esta una buena pregunta?
Your base station is reporting some sort of problem; you need to run the Airport Utility on your computer and connect to it to see the exact error message.
See also http://support.apple.com/kb/TS1589
Fue útil esta respuesta?
Amber light may mean that you lost Internet connection or that you have double NAT.
A persistent, flashing amber light indicates that any of the several potential conditions may require your attention:
• The base station has not yet been configured because it is new, or the reset switch has been set.
• You have selected a security configuration that is not recommended.
• A new firmware update is available for the base station.
• One of several other conditions, such as a disconnected Ethernet cable or invalid IP address has been detected.
ref: AirPort base stations: About AirPort base station status lights (LED)
To find out why your base station's status LED is flashing amber:
• Open AirPort Utility
• Click on the AirPort base station
• Look for a Status setting in the small window that appears. Note: Status only appears if there is an issue or notification.
Click on the small amber dot there and another window will open to explain what the "issue" might be.
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 52
Todo El Tiempo: 13,728
