Saltar al contenido principal
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
Preguntas 426 Ver todo
Is my quesstion being avoided
My question is now on page 9 along with mostly questions that have been answered. If there is no solution I need to know that as well so I'm not waiting for something that isn't coming.
Maybe there is an answer for this one. I have a new HP Slimline Desktop, my question is about the keyboard. The keys are so sensitive-meaning they repeat faster than I can type so when I look at the screen the word look is loooooooooook or the word screen is scrrrrrreeen. Is there a way to adjust the keys ? I am a pretty fast typist so I don't believe it's me & I've not had this problem before.
Thank you, I hope someone will help me with both but an answer or some kind of response would be helpful.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
Here's a video on how to replace the digitizer: https://www.youtube.com/watch?v=V-bFHycv...
Here is a source for the part: http://www.actablet.com/digitizer-touch-...
Fue útil esta respuesta?
Puntuación 3
If there is a way to change keyboard settings it will probably either been in the control panel under devices or accessibilities. Look up how to turn on/off "Sticky keys" in your version of whatever OS you are using
Puntuación 0
La respuesta fue originalmente a otra pregunta.
It sounds like the touch screen digitizer has been damaged. Not sure if for this device you can replace just the touch part or you have to replace the LCD/touchScreen all in one piece but it sounds like if you get the screen replaced it should be good as new. Also the innards won't fall out so connect it to the keyboard. If the keyboard and mouse still work the you can either not use the touch screen or just get the screen repaired
Puntuación 0
Añadir tu respuesta
Judie Scoville estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 170
