My bottom of screen
Hello guys help me please, the bottom of my display has an yellow colour, and the touch doesn't work in the bottom of my screen for HTC one m8
Es esta una buena pregunta?
First thing to try would be backing up all the data and factory restoring the device.
If that is unsuccessful then you will need to open the phone up to try resetting the screen cables. Opening an HTC One M8 is quite tricky and I don't recommend it for a beginner. Follow along with this guide
HTC One M8 Display Assembly Replacement
to get the back open and rather than remove the screen altogether just remove and reinsert the two screen cables making sure they are all the way connected and sitting flush.
If the problem still occurs you will need to replace the LCD assembly, order a new screen and again follow this guide.
Also make sure to read the comments on the guide as they point out a few things that are not clear in the guide itself.
Good luck!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 138
