Saltar al contenido principal
The Dell XPS 15-L502X laptop was manufactured by Dell Inc. It was released in 2011 with a 2nd Gen Intel® Core™ processor.
Annoying sound and overheating
How to fix the annoying sound and tends to heat up quick after just around 2 hours of usage?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Are the internal fans spinning? Did you clean the vents on the unit?
- de
What is the annoying sound. Do your hear a ticking sound or do you hear the fans rev up to maximum speed ? Something is causing the laptop to over heat. I agree with Brian on his suggestion. Do you see any dust or lint blocking the air vents ? Do you notice the bottom of the laptop getting hot ?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
How old is it? Older laptops tend to clog up their heat-sinks with dust causing them to overheat and make the fan spin faster.
However, if you hear the fan actually grinding the bearings in the fan might also be broken. If this is the case, you need a new fan.
For the dust issue: The best solution is to open it up and clean the dust out yourself.
However this does require some work and is semi risky depending on your technical skill.
https://www.youtube.com/watch?v=AD5jpqVo...
If you dont want to do this, you can also try to get some compressed air and and blowing it into the air exhaust to get the dust loose.
  • Warning: Do not blow for more than a second in a row, the air will cause the fan to spin too fast and break.
  • Warning 2: Do not hold the compressed air can upside down. while spraying.
  • Warning 3: This solution is only temporary, you are going to have to open it up and clean it eventually.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
testoutjian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 680
