Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, manuales y ayuda para la resolución de problemas de 1993–1997 Ford Ranger. Accede a todo lo que necesitas para reparar tu 1993–1997 Ford Ranger tú mismo.
How to adjust rocker arms on 4.0
how do i adjust valves
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Betty Ayers your 4.0 Ranger has hydraulic roller cam followers (lifters) and you do not adjust hydraulic lifters. If you have valve noise etc it is possible that you have some pitted or worn push rods. If you let us know what makes you think you have to adjust your valves, we could possibly help you further.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
4.0 was bad for lifters going solid. The lifter stops taking oil it deflates and stays solid causing push-rods to ring. this is usually followed by a failure of the timing chain
- de
Is there anything I can do to quiet down how about if I just put new push rods in
- de
Or is the rocker arms bad too
- de
@john76866 only you will know if the rocker arms will be bad. I prefer to replace both of those (rocker arms and lifters) since that way I do not have to tear it down again. Yes. it's an additional cost but it evens out since I don't have to tear it down again
- de
Añadir tu respuesta
Betty Ayers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 2,864
