Saltar al contenido principal
La cuarta generación de la tableta Surface Pro, lanzada el 26 de octubre de 2015.
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
1 comentario
answer is not even about the hinge, only addresses the easy answer
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Microsoft Surface RT Kick-stand Replacement
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
answer does not address the broken hinge!
- de
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
- de
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
- de
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
- de
not helpful--hinge broken & not the stand
Puntuación 2
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Puntuación 0
Hi Grant,
To replace the right hinge, you'll have to open up the tablet. You can do this by following this very helpful repair guide!
Reemplazo de la bisagra del soporte de Microsoft Surface Pro 4
Puntuación 0
Añadir tu respuesta
Grant Smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 15,724
