Screen only shows gray and black lines?
My Tab only displays black and gray vertical lines, but I can hear that the unit is powered on, what might be the problem? Is it repairable? Thank you!
Es esta una buena pregunta?
Looks like the LCD for this went bad or became loose from the board itself. It is definitively repairable, but I do recommend that you purchase the LCD and Digitizer assembly if you are going to do this yourself.
Fue útil esta respuesta?
I had the same problem replaced the screen and digitizer and still it's black with gray lines
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 748
