transmission is stuck in reverse
who do get a maual trmission out of reverse?
Es esta una buena pregunta?
Hi
Adjust the clutch wire..leading to the gear box
or push the clutch arm on the gearbox..while someone in the car pushes on the clutch peddle then wiggle the gear stick free!
Happy driving
Ray
Fue útil esta respuesta?
MY Mechanic friend found on another blog that this is a common problem for some early years; even after a recall repair. He said remove reverse light and use a small flat screw driver to move actuator....With a $50 tow and $25 repair, I guess we all may have learned a leason.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,551
1 comentario
Thanks Ray for the effort!!
- de RICKY WEEKS
