How to open FireTV Stick remote
Any creative ideas for how to open the fireTV Stick remote when you first get it?
Es esta una buena pregunta?
The two best options, as it turns out, are 1. Just pull really hard, or 2. Use a screwdriver to pry it open.
Here is a YouTube link that shows how:
Fue útil esta respuesta?
I went down the screwdriver route. Many thanks for the suggestion.
Simple once you know how. Hold BOTH ends of the remote, squeeze both ends gently and slide forwards
I agree. Sometimes, the new plastic pieces have micro texture edges resulting from the fresh cutting from the making of the pieces that give it a bit of a grip against each piece to where you will need to use something that allows you grip it better, like rubber gloves, or even a rubber band. I too had serious trouble opening it the very first time. I used latex gloves to open mine once, after that I could open it easily with bare hands. If you put a rubber band on your thumb and push it open that way, my bet is that it will open for you.
Latex gloves worked - still have to push hard - Thanks
The person who designed this remote should be fired. Seriously.
Couldn't agree more. It's totally ridiculous for such a sophisticated device to be missing a little notch to open it easily.
I received the Amazon fire stick remote today, and took me quite a while to figure out the best way. Every time I press on the indent and move it up it opened a teeny weeny bit, and not any more. So finally, I pried it open a little and put in the batteries
Phew! Ridiculous! Took suggestion from YouTube & used rubber jar opener to gain traction while pushing down-still very tough!
Watched a video on YouTube with a very simple trick that works great. Turn the remote over so the little arrow is pointing up. Grip it firmly in your hand and hit the end firmly on a hard surface. If you do it right, the back cover pops right off. I got it off on the first try.
Ultimas 24 horas: 6
Ultimos 7 días: 42
Ultimos 30 días: 181
Todo El Tiempo: 35,653
