How can I fix the antena of the NIC from a laptop?
Hello,
While i tried to fix some problems of a laptop, accidentally I broke the antenna of the NIC. The wire and the gold prong just broke off. I tried to reconnect putting the wire inside the gold prong and it seems right but, after that, the WiFi Signal is too weak. How can I fix this problem? There is some way to reconnect the gold prong and the wire?
Thanks!
Es esta una buena pregunta?
2 comentarios
Please give us the make and model of your system.
You likely will need a replacement antenna cable. But without knowing who's system you have here I can't offer you more. Posting a good picture might be helpful as well.
- de Dan
Asus UX303L. The only way is replacement? Can´t I tin solder wire?
- de Ramon Paris
