How do I fix a refrigerant leak in the ac?
My a/c line has a leak in it and I'm trying to fix for as cheap as possible. Any help would be appreciated.
Es esta una buena pregunta?
Logan Winward you still have to determine where it is leaking and which line it is. Once you find the leak, there is usually no way of fixing it (unless it is a gasket or O-ring, which is unlikely). Most of the time it will require the replacement of a damaged AC line.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 19
Todo El Tiempo: 130
