Saltar al contenido principal
IBM es la compañía pionera de la PC moderna
Why do coloured,vertical stripes appear on my R52 Thinkpad screen
Almost 5-7" of the laptop screen gets covered with thin vertical lines on starting the computer.Lines do not appear when adapter is used to connect laptop to another monitor.Is this a 'display' or a LCD problem?Please advise what can be done?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Respuesta Más Útil
This is LCD screen failure. You'll have to replace the screen.
IBM/Lenovo laptop repair guides.
Fue útil esta respuesta?
Puntuación 1
Those are raster lines and if the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Some panels have issues with the connector that carries the signals. So check your wiring, connections etc. Your video card itself seems to check out since you have no issues with an external monitor. If none of this resolves your issue, follow LaptopRepairGuy's advise and replace the panel. Good Luck
Puntuación 1
how to repair vertical line in my ibm thinkpad g41
Puntuación 0
1 comentario:
saubhagya, are you asking how to fix it? See Laptop Repair guy comment as well as my own. http://tim.id.au/laptops/lenovo/thinkpad... shows you how to approach it. Good luck
- de
I had thin red vertical lines on my screen of my T430 Thinkpad. I solved this by disconnecting and blowing air on the connector and reconnecting the screen cable just next to the right hinge
Puntuación 0
Añadir tu respuesta
Harry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 5,465
