Saltar al contenido principal
Este dispositivo es una máquina de bebidas caseras fabricada por SodaStream. El propósito de este dispositivo es hacer bebidas gaseosas en la comodidad de tu casa con el uso de jarabes y la máquina. Este modelo en particular fue fabricado originalmente en aproximadamente 2007.
need a new carbonating button
The carbonating button on my Sodastream Jet has broken - cheap piece of plastic. This is the 3rd one it has happened to. Does anyone know where to buy one? The pin slides out just like on a watch band.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
1 Respuesta
There are many used machines on Facebook marketplace or Craigslist that you can find and buy and then use them for repair. I for one found that the button depresses too much and it sounds like that is happening to you, hence the breakage. I took some popsicle sticks, cust them to make an inch length, glued them together, and glued them between the button and the housing. Then I didn't need to press so hard to get the carbonation out of the can and into the bottle. Hope that helps for any future endeavors.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
virginia ashburn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,609
