Saltar al contenido principal
Información de reparación de congeladores.
Preguntas 197 Ver todo
Why is my upright freezer leaking a "lot" of water from underneath?
My upright freezer is leaking a "lot" of water from the bottom! I don't think it is quite as cold as it usually is, but the food is still frozen. I hear a noise, but not sure if it is just a fan, or motor, or compressor. Don't think it sounds as it normally does. The water covered my entire garage floor...I can feel cool air coming out the vents on the inside, but the foggy stuff isn't circulating.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Cause 1
Clogged or Freezing Defrost Drain
During the freezer’s defrost cycle, the defrost water exits through the defrost drain. Sometimes, the defrost water can freeze over the drain. If the defrost drain is clogged with ice, the defrost water will overflow the drain and leak from the bottom of the freezer. To thaw the ice inside the defrost drain, use a turkey baster and hot water to flush the drain. If your defrost drain freezes regularly, consider installing a drain heater to melt the ice.
Where do you live an how cold is it in your garage?
Fue útil esta respuesta?
Puntuación 8
1 comentario:
It is not in garage but in the basement, which is set at 68F. Ontario, Canada
- de
my door was lift open by mistake none it will not freeze all the can you please help.
Puntuación 0
2 comentarios:
my freezer leaks from underneath ive told my new landlord but he just says thats what happens its about 6 yrs old it never did that before
- de
my freezer is leaking from bottom my new landlord says its ok thats what happens but it has never done that before its 6 years old
- de
Añadir tu respuesta
gracie1rda estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 20
Ultimos 7 días: 112
Ultimos 30 días: 545
Todo El Tiempo: 53,277
