Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.3, 2.6 o 2.7 GHz (Turbo Boost hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 561 Ver todo
Low humming sound coming from near the right fan. What to replace?
My wife's MacBook Pro was dropped a while back. Ever since it has made a low humming sound that drives me crazy. It seems to be coming from the right fan and indeed sounds like a rotating noise.
The heat sink was damaged in the fall, and I have already replaced that. I was hoping that would fix the noise, but it did not.
While replacing the heat sink, I also removed the right fan, inspected it for damage, and cleaned it thoroughly. I did not see any damage.
I need help diagnosing the problem so that I know what part needs replaced. I can easily replace the fan, but I am afraid this is not the problem, since I cannot find any damage to the fan.
Any help would be greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
jkgarrett17 did you ever solve your problem? I am running into the same thing and its driving me insane.
- de
Never did solve it. I replaced both fans, the heat sync, and even had the standalone GPU replaced. It’s better, but still makes a slightly nauseating hum. Sorry I couldn’t be more help.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Diagnostics on these kind of problems can be both easy and frustrating at the same time. Luckily one thing is certain: the only thing that can cause a noise like that is a mechanical part.
Since the MacBooks only contain a few rotating/moving parts, the diagnose is easily procured. The fan is indeed suspect number one: a slight imbalance in the blades is very hard to spot, but can easily create the noise. The bearings can have a similar problem, and aren't even visible from the outside.
I would try to get the machine running and gently stop the fan with your finger for a very short while. It'll tell you enough to hear if it's the problem.
If it isn't the fan though, repeat the process with all other moving parts, including traditional hard drive if still present, and replace accordingly
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I would add most of the time its dust build up that can be easily cleaned with a soft paint brush to help scrub the parts to loosen the dust and a can of can'ed air to blow it out.
- de
I would also add that if there is any damage to the case this could be the issue I've had a MacBook that was badly dented at the rear and made noise no matter which part I change it was the case itself with the combination of the moving part ie the fan
- de
Añadir tu respuesta
jkgarrett17 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 782
