Why wont the turntable platter spin?
When I try to power on my record player, the turntable platter wont spin. It doesn't spin regardless if the record is on it or not, so no music plays. What should I do to fix this?
Es esta una buena pregunta?
The most likely cause of the problem is that the motor is broken, preventing the rotation of the platter. In order, to fix the issue double check to see if the platter itself is damaged or broken. If, so replace that; in addition if it is not just the platter, go into the device and replace the motor. The attached guide for the Turntable Platter should assist in guiding you through the whole process found here [enlace de guía no válido]
Fue útil esta respuesta?
Since this is a belt driven turntable check to see if the belt is on . This is located under the round metal platter you set the record on. There may be a clip holding on the platter so if there is you will need to remove the clip before the platter will come off. If the belt is off the platter will not rotate or turn. It also me be stretched or broken. If you have an owners manual it will till you how to put the belt on.
If the motor is broken. Could it be replaced. It’s a TT2200 Marantz model
I just got mine out of the box and had the same problem. The hardest part was removing the little clip to get platter off. It doesn’t screw off you have to just push it off. Once the platter was off the belt was clearly off track. Wrap the belt around the platter and the little knob that turns as you put the platter back on. Put the little clip back on and boom. Back in working order.
Can you show me?
Did you check the belt like a mentioned above? What type of turntable is it?
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 96
Todo El Tiempo: 67,972
6 comentarios
Just got mine and it only spined the first day and now I plug it in and turn it on and it don’t work anymore
- de Girly Gamer!
- de electricdime
Im having the same problem, it was spinning before I took the needle cap off and when I took it off and placed it on the record it stopped spinning
- de clusby7
Did the check.. the belt was off, then we put it back on. The turntable still will not work. Everything else is working fine.
- de gracefull11826
I lost my manual.So what should I do now?
- de gracefull11826
Mostrar 1 comentario más
