Saltar al contenido principal
La Panasonic LUMIX DMC-LX100 es una cámara digital compacta con resolución de 12,8 MP, capacidades de video 4K HD y acceso Wi-Fi. Fue lanzada en noviembre de 2014.
Preguntas 23 Ver todo
Losing date and time when main battery removed
When I recharge my battery the camera loses the date and time. All other functions appear to work. When the date and time is reset it is correct until the battery is removed again. Can this be fixed easily?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
There is a tiny watch size battery cell on power board, top right side (view from LCD side) under top cover. Little challenge to replace as it's really small and It is welded to a two flat steel lines (not soldered). Not sure the voltage as mine is also dead and shows 0.6v and it has no any markings on it. Could be around 1.5v but can also be a 3v. But seems that there is an extra room around for a larger size cell may fit.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Mike, had you replace the battery? what model of battery did you buy?
- de
Respuesta Más Útil
See if there is an additional CMOS battery that would handle that.
Puntuación 4
1 comentario:
There's no mention whatsoever of an additional CMOS battery in the user manual, so most likely if there is one it's not user replaceable...
- de
I read in another forum that the camera may only charge this "time keeper" battery while on, so leaving it on with no sleep mode and the LCD off overnight mat be enough to charge up the tiny internal battery.
Puntuación 0
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 912
