Why is my headphone not working?
The audio on the headphones fail to work completely. The audio may be cutting in and out, only working on one side of the headphones.
Es esta una buena pregunta?
There might be dirt build up or water damage in the audio jack, but try a new pair of headphones to see if the headphones are the problem. If they are not the problem because they work fine for your other devices then replace the audio jack in your device.
Fue útil esta respuesta?
may be a lot usage of ur headphone may damage the fibres of your headphone and also may be the magnet used is wrecked or maybe the soldering used to attach your headphone speaker and the pin may be damaged due to over use.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 481
