Saltar al contenido principal
Un procesador de alimentos compacto con un raspador de tazón interno fabricado por primera vez en 2012.
Preguntas 3 Ver todo
Why is there a burning smell?
My Hamilton Beach Food Processor is giving off a burning smell when I turn it on, though everything is running fine.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
After the manufacturing process, the motor will often be left with residue. This is a temporary odor and should go away after repeated use. If the smell is reoccurring, stop using the device, as the wiring is more than likely faulty in the device. Also, as a side not, make you are only processing food, as "processing" anything else could lead to some odorous results as well.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Spencer Lynds estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 3,206
