Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El reloj Pebble E-Paper es un smartwatch desarrollado por Pebble Technology y lanzado en 2013. El proyecto esta en continuo desarrollo y fue fundado por las contribuciones de usuarios de Kickstarter.
What screwdriver do I use? (OG Pebble w/4 screws on back)
I heard it was a Torx. Upon further research I discovered there are different types of Torx. The screws securing the back of the Pebble Classic down do in fact have the pin in the middle of each screw from what I can tell. Can someone point me in the direction of the cheapest possible online source to purchase the correct screwdriver to open up my Pebble?
I RMA-ed it and the replacement is on its way - but they're letting me keep my current one so I'm going to try to fix the screen tearing using the method I saw on YouTube with the shim adding pressure to help ensure a solid connection for the display cable. And if something goes wrong beyond fixing, then I'll just go to a facility to recycle it like Pebble Support told me to. It's the defective one anyway.
Model 301BL, the later version that actually can be opened without completely wrecking it.
I just have to tell myself that it won't be long before I have an Apple Watch Sport. I'm willing to sacrifice battery life for something that will actually work.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I found that the T5 Torx was the one that fit the screws.
Fue útil esta respuesta?
Puntuación 2
Sounds like the model you have uses Torx-Security screws. We have a few different sizes, but this is one of our smaller ones:
TR6 Torx Security Screwdriver
Imagen de Precision fixed blade screwdriver engineered by iFixit.
Producto
$5.99
Puntuación 0
Torx 5 is what I used. Fit perfectly
Puntuación 0
Añadir tu respuesta
roycerivard123 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 59
Todo El Tiempo: 4,246
