Why does my battery die very quickly?
After charging my battery throughout the night; i begin to use the drill. After a few minutes of use the battery completely dies. What do i do?
Es esta una buena pregunta?
When this problem happens it could be one of two things.
The battery may no longer be holding a charge and therefore a new battery must be used.
Another problem can be because of the battery charger. The charger may have a connection problem and thus the battery isn't being charged probably. follow our step by step guide (the guide hasn't been completed yet)
If you need more help check out our Troubleshooting for more information
Fue útil esta respuesta?
Your battery is no longer holding a charge. Meaning you needs a replacement.
Funny. I have that same drill and got it when my dad died. He had owned it forever and used it all the time.
Mine still holds a charge for a very long time but I use it a lot.
I have a B&D leaf blower that lasts about 30 seconds. I’ve tried everything, leaving it on until it’s completely drained, using it often…nothing seems to work on that one.
I have two batteries charging simultaneously on two different chargers and they both drain too quickly to finish edging my lawn. Is it time for a new trimmer. Seems unlikely both batteries are going bad at the same time. Thanks.
I have 2 black and decker cordless drill batteries I bought at the same time. I used one while the other charged and switched them next time I used it, but now one dies way too quick and its basically new compared to the original batteries . I think one of them might actually last longer, argh frustrating.
Ultimas 24 horas: 7
Ultimos 7 días: 49
Ultimos 30 días: 197
Todo El Tiempo: 10,235
