Saltar al contenido principal
La actualización de marzo de 2015 del MacBook Air de 13" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento ligeramente mayor y una mayor duración de la batería.
Preguntas 20 Ver todo
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
Emmanuel Marti check the attached image for location.
Fue útil esta respuesta?
Puntuación 10
7 comentarios:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
- de
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
- de
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
- de
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
- de
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
- de
Mostrar 2 comentarios más
Añadir tu respuesta
Emmanuel Marti estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 24,266
