Saltar al contenido principal
Modelo A1419 / Finales de 2012 / Core i5 de 2,9 y 3,2 GHz o Procesador Core i7 de 3,4 GHz, ID iMac13,2
Preguntas 330 Ver todo
LED #1 blinks when connected. iMac not turning on
Hi. I have a late 2012 iMac 27 inch. This morning I tried to turn it on and nothing happened. I removed the screen to see what's going on. On the logic board, I can see that 1 LED is blinking. When I press the power button the LED resets the blinking but it never stops. I've been looking everywhere to determine what this blinking LED mean. PD. It is the only LED on, the other 3 of them are off. Thanks
Es esta una buena pregunta?
Puntuación 4
3 comentarios
Did you ever figure this one out? I have similar issue. Thanks!
- de
I have similar issue. =(
- de
There is somebody who could fix this up?? Any help on this issue? Please. New power supply is not the problem.
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Well it's a bad power supply. But not really that bad. It can probably be fixed with just a little work over with a soldering iron. It's late and I'm going to bed but Google "cold solders" and how to fix them.
UPDATE 3/16/16
https://learn.adafruit.com/adafruit-guid...
https://www.youtube.com/watch?v=h5_dBMuJ...
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Thank you so much! I'll be trying to find some information about cold solders. Hope to find something. Can this be tested with a electronic tester? Thanks again!
- de
I just installed a new power supply! And guess what? The blinking Led 1 Still there... So the blinking led means something else that we could not find clear information
- de
there is shorting of some sort on the board its called cpu v sense I have the same ISSUE ON 820-00291 2015 27 INCH IMAC check with a magnifier for blown out components rusted tracks
- de
if you remove the cpu the blinking light first led will be solid stable
- de
If there’s an LED coming on, then the power supply works - at least, well enough to power the LED.
An LED coming on (and maybe blinking) is a code for a variety of RAM/BootROM errors. Apple used to have a support note on this, but I don’t seem to be able to find it now. However, the University of Oregon has a reference:
https://it.uoregon.edu/node/3308
UofO’s list of blink error codes matches my memory, and is as follows:
  • Black screen, power LED on (solid): POST or BootROM failure
  • Flashing power LED once per second: bad RAM or no RAM
  • Three flashes, a pause, and three more flashes (occurs continuously): marginal RAM
If the LED is blinking, I’d try replacing the RAM. If you have no compatible replacement RAM, at least remove the RAM you have, clean off the contacts on the RAM sticks with a pink rubber eraser so they’re shiny, scrub out the RAM sockets with a soft dry toothbrush to get any gunk out of them, and try booting with the cleaned/reinstalled sticks.
It’s possible that one stick may have gone bad, while the others are still OK. Although installing in pairs is preferred for this generation, you can try each stick individually to isolate any stick that may have failed, and replace only the filed ones.
In the event that any of the followup commenters have a solid LED, the only way to repair the Boot ROM is to reinstall the operating system. You may need to reformat the internal drive as well, if the drive blocks where the old Boot ROM are physically damaged.
Your best bet is to boot from an external drive (hard drive or flash drive) with Disk Utility and an appropriate OS installer. Use Disk Utility to repair the internal drive first, then see if you can restart. If not, then try to reinstall the current OS. That will replace your damaged system software without altering your user account.
If that doesn’t work, then the safest thing is to boot from an external boot drive, clone your internal drive to a second external drive (using Carbon Copy Cloner or SuperDuper!), then erase (or reformat) the internal drive using Disk Utility, reinstall the operating system, and restore your applications/user accounts from your clone or from your last trustworthy Time Machine backup.
If you have a reliable and reasonably speedy broadband connection, it’s possible to boot your computer from an online Recovery Disk using keyboard shortcuts, and do repairs/OS reinstalls even if you don’t have an external boot drive. Different OSes can be reinstalled by different methods, depending on what OSes you’ve used before.
https://support.apple.com/en-us/HT201255
https://support.apple.com/en-us/HT204904
Puntuación 2
4 comentarios:
LED 1 should come on and stay on till the ON button is pushed, the power then goes to the RAM, logic board etc. after that, nothing to do with these parts only the power supply. Download and read the Service Manual.
- de
Also, my 2010 27 iMac has a flashing led 1 until I press the on button then LED 1 and LED 2 stay lit and it starts up but no backlit on the screen, I have been using an external monitor for about 3 years now and that works fine. I have placed a small mirror on the base below the lights next to the ram panel and I see this behavior every single time I start up. Whats funny is if I don't press the on button when the LED 1 is in the lit stage it will not start. Then when the third LED lights up the external monitor gets its picture and all is well. Hope this helps some people.
- de
Bad ram or no ram have audible beeps (look it up) or are usually just not recognized if you have good ram installed that it can start with. Boot Rom and other such problems usually end up with a kernel panic.
- de
"Quote" "Bootrom (or Boot ROM) is a small piece of mask ROM or write-protected flash embedded inside the processor chip. It contains the very first code which is executed by the processor on power-on or reset." In this case, It does not reside on the Hard Drive. The hard drive has its own Boot Rom as has absolutely everything else with a chip on a board ie; everything else electronic. The chips have to "Talk" to each other for success of operation. Hope this clears up some confusion on the matter
- de
Maybe it's the processor, but I could not test it because it was old ...
Puntuación 0
Have similar problem. I thought it was my i7 cpu, but cpu works perfectly at another machine.
I give 12v to motherboard with my bench psu (cooling was off).
I found that the led start blinking WHEN i press cpu at the top left (around pin 221). I saw at boardview that this side is for communication with ram. With another cpu i have the same problem. I put a piece of paper to cpu pins to isolate the problem.
Even with the ram dimms off, the problem exists. Ram slots seemed perfect. Cpu slot pins seemed perfect.
edit: Possible some secondary voltage was short. Found a low resitance (can’t remember how much) at PP3V3_S0 that i didn’t like, i inject 3v to check for hot areas, didn’t found.
Then i assemble machine, boot it and works.
Tried Apple Service Diagnostics, passed all tests.
Hypotheses:
It’s magically fixed (temporary or not)
It’s something missing (still i didn’t find it)
Blow the sd reader slot for dust, i might remove some piece of wire stucked within.
I did something without my knowledge that fixed the problem.
Puntuación 0
i have similar problem, but i have solved it. Power supply is good but logic board have a short. That’s why, system is in a power cycle, so led 1 is blinking. Your system try to boot up, but there is an short on your logic board.
check the voltage rails from schematics. S0, S4, S3 and s5 there must be and short.
Puntuación 0
2 comentarios:
Hello there, can you send me that schematics please. I can’t find those spots you mentioned. Thanks
- de
Just google your logic board model number. You can find it on google.
- de
Añadir tu respuesta
manuelt637 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 77
Todo El Tiempo: 6,303
