Saltar al contenido principal
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
Preguntas 35 Ver todo
rapid power loss power dives from 100% to 3% in seconds
the power reading reduces from 100% to " critical battery power" in about 10 seconds after take off any advice . tried two new batteries same result. Charger charges back up to green within 15 mins. switch off copter and reboot shows the power at a level you would expect (80-90%) than does the same again when you you press take off. any advice ANYONE cheers
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Try a different charger and measure the battery voltage if you have a multimeter.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
colin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 76
