Saltar al contenido principal
La Coolpix P530 es una cámara digital de 16,1 megapíxeles con un impresionante zoom óptico de 42x. Este modelo fue lanzado por Nikon en febrero de 2014. También tiene el nombre de modelo específico del fabricante Nikon 26464.
Preguntas 20 Ver todo
Why is my camera not turning on?
When I noticed that my camera battery was dead, I plugged the camera into the AC adapter to charge. However, the camera still will not turn on after charging the battery for several minutes.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
4 comentarios
Im having the same problem but with the battery being completely charged it still wont turn on. What is the problem?
- de
got it resolved at mata Bangalore contact mataelectronics@Gmail.com
- de
i have the same problem . batteries charged ( 3 different ) connected to Pc and to USB .... but no signs from camera .... dead. do you have any solution?
- de
@Bitu Kotai Please . post your solution to the mentioned problem.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If your camera will not turn on, ensure that the battery is charged. It is a possibility that your camera may be unresponsive even while plugged into the AC adaptor. Your camera will not turn on until sufficient charge has been obtained. If the battery is charged, the camera could be overheated. If this is the case allow the camera to cool down in a place away from direct sunlight or sources of heat. For more helpful information about this problem or any other issues check out the Nikon Coolpix P530 Troubleshooting page here on iFixit.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Sydney Cardinali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 8,052
