TBI to aspirated conv
Having issues with fuel pump not staying on after converting from tbi to carburetor, do have Holley fuel pressure regulator installed already
Es esta una buena pregunta?
Are you using the original fuel pump or are you using an aftermarket electric pump for carb engine What are you using to regulate the pressure Is the holly pump a single or double pumper. All these issues need to be addressed when switching to an electric pump from mechanical on a carbed engine
Fue útil esta respuesta?
I forgot to mention it is a 1990 1500 has stock in tank electric fuel pump, I'm running a holley 12-803 fuel pressure regulator which has in out and return all are hooked up in running an edelbrock 625 that I rebuilt the other day becaus my needles were sticking.
you may want to remove the tank pump and put in an inline electric pump. The stock in tank pump requires a constant back pressure and without it it shuts down. Most stock EFI return lines are too small for a carburetor conversion, creating more backpressure than the regulator. - See more at: https://aeromotiveinc.com/frequently-ask...
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,031
2 comentarios
You're my best friend
- de Cody Rozema
- de Gaige Alleson
