Camera is stuck on backward view
My camera is stuck so I only see myself on the screen! Please help
Es esta una buena pregunta?
Hi,
You have 2 options:
Flex cable (camera, light sensor, earspeaker) is damaged and you have to replace it, check ifixit.com for spareparts.
Connector is not in possition, you have to fit in the good way.
Regards.
Luis
Fue útil esta respuesta?
Thank you. Not convinced but will try your suggestion.
Otherwise you can clean the connectors with a brush, sometimes its just dust, I suspect the phone could be "water damaged", check the upper water sticker.
Good luck! ;)
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 40
