Saltar al contenido principal
Anunciado el 9 de septiembre de 2015, el iPad Mini 4 mantiene la potencia de un iPad Air 2 en un factor de forma más pequeño.
Preguntas 176 Ver todo
Will replacement glass and digitizer work on the Ipad Mini 4?
My son broke his Ipad mini pretty badly. I have the heat gun to remove the glass. I want to order new glass. But the ipad 4 is way more expensive than the other 1,2,3 models. What model and digitizer can I use?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
The reason the iPad mini 4 is more expensive is because the digitizer/touch screen are glued to the LCD, so you have to replace both, making for expensive repair. Doing a glass only repair on the iPad mini 4 would be near impossible without the expensive and high tech tools. The iPad mini 1,2,3 the digitizer and LCD are not glued together so if the screen is broken you can just replace the digitizer/glass.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Hi. there, I have an Ipad Mini 2 the Screen is cracked. do I have to replace the LCD and Digitizer ? can you please explain why. Thank you!
- de
Just the glass only in the iPad mini 1/2/3 much cheaper repair.
The 4 has a glue between the entire lcd and touch digitizer so you cannot split it apart like the 1/2/3 models.
- de
From what i understand
you want to use another glass/ digitiser from iPad mini 1,2or 3 on and iPad mini 4
if this is correct you can not use any other glass/ digitiser on iPad 4 other than what was intended sadly
Puntuación 0
4 comentarios:
also if you don't mind me asking how much is a new digitiser
- de
New digitizer is around $220
- de
now i know this is more expensive but you get a new iPad?
https://www.apple.com/support/ipad/repai...
- de
I don't think the ipad you get is new; I believe it is refurbished with a 90-day warranty. However, it may indeed be the best option.
- de
Hi I had tried to separate the glass and the LCD and and punctured it. Now not working. Can i buy a new LCD to replace? How much is it? Will I need to keep any part from my old LCD for use. This is a mini apple ipad 4
Puntuación 0
Añadir tu respuesta
Jenny Minerva estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 9,972
