Saltar al contenido principal
Repair manuals and information for the Microsoft Surface book line of laptops.
Can I replace the SSD drive? (current one is defect)
Microsoft International Warranty doesn't work if you buy from USA and want to ask for warranty in Europe.
I have the option paying almost entire device cost as custom fee and shipping, throwing to the garbage bin, or repair it.
To repair I need to open it and replace the SSD drive. Would you recommend this route? How risky is... do you know the type of SSD used?
Many thanks,
Gia
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
5 Respuestas
Solución Elegida
the surface book has not got a normal ssd it is pci style ssd so don't buy the ssd before you see what you need . It can be a bit of a pain to get into but if it comes down to chucking it or repairing it give, it a try
Microsoft Surface Book Teardown
this teardown guide may be helpful and good luck . Hope this helps
Fue útil esta respuesta?
Puntuación 2
Yep, actually I replace the SSD in my Pro 3 i believe it's the similar way on Surface Book
Puntuación 0
Hello!
Is it possible to use a hairdryer instead of the "iOpener"?
If yes, what would be the precautions to take on?
Thanks
Puntuación 0
1 comentario:
Possible, but suboptimal. The glue is strong and your hairdryer probably won't get hot enough, A Heat Gun available at a local hardware shop would be better, but be careful, you don't want to damage the screen through over heating that might damage the panel or too much uneven heat making the glass vulnerable to cracking. Take care to apply heat evenly and have many guitar picks and suction cups ready.
- de
I also want to replace the ssd and would like to know, if you really have to take out the Mainboard to access the ssd.
In the video they do it in that order but the metal shelf is visible as soon as you remove the screen…
Greetings from Germany :-)
Puntuación 0
Unfortunately, this is happening all around Europe if you buy Americas products. But, you can change it with a new PCIe3 SSD.
Puntuación 0
Añadir tu respuesta
giabetiu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 5,007
