Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LeapFrog LeapPad Platinum 31565 combina una pantalla multitáctil de 7" de alta resolución con un potente procesador de cuatro núcleos. Es el último modelo de la línea de tabletas de aprendizaje de LeapFrog.
Why is my touch screen is not responding?
My touch screen is not responding even though I've tried to restart the LeapPad many times.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
It's likely that the screen is just dirty. Try cleaning it with a microfiber cloth (like the kind you would use on a pair of glasses). If that doesn't work, there may be crumbs or other messes stuck in the edges of the screen (this can be enough to throw off the screen's calibration). If you see any messes in the cracks around the screen, try gently removing them with a toothpick or a spudger. If that doesn't work, you may be dealing with a larger issue like a damaged screen or a loose connection. If you think this may be the case, take a look at the LeapPad Platinum's troubleshooting guide to help you diagnose your problem and find the right guides to replace any damaged parts.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Leann Nguyen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 6,134
