Can read or access memory card
when taking shot, camera can't read memory card, i replaced several cards but did not work
Es esta una buena pregunta?
The memory card must be "formatted". The camera can not read from, or write to, a card that has not been formatted first.
The quickest way to format a memory card is to use the camera's built-in formatting utility:
If you get an error message during the formatting process, there are two likely causes:
As a last resort, you can try to wipe the card contacts with a clean tissue, and insert/eject the card a few times to clean the socket contacts.
If the formatting process was executed correctly, the card should work, and the camera should be able to store your photographs on the card without any errors.
If the camera still gives error messages even with a card that is known to be good (will work in a different camera or other device) the card socket may be defective, but this is a relatively rare problem.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,839
