Saltar al contenido principal
El Samsung Galaxy Note 4 es un teléfono inteligente celular que fue lanzado en octubre de 2014. El número de modelo del Galaxy Note 4 es SM-N910, SM-N910A, SM-N910T, SM-N910V o SM-N910R4 para las variantes americanas.
Preguntas 261 Ver todo
How to fix samsung galaxy note 4 wont run?
When I turn on my Note 4, yes it will still display a logo for samsung, but it will not run until it will display the menus. it will just show the "blink" sumsung logo or word. Please help me fix this one, i baught my phone in Thailand.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Can it boot up if connected to a wall charger? Did this take place after trying to apply a system update? Have you tried to hold any button combinations to try to boot into recovery to perform a factory reset? Has the device been dropped or had any other incidents?
- de
Had same problem took to Samsung galaxy repair person ,told me my phone was a clone and couldn't do anything to it.watch out for this when you bye one from a person or ebay.i know what to look for now
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi Rodel
Try to restore to factory settings.
1. Turn off your Galaxy Note 4.
2. Press and hold Power, Volume Up and the Home button until you see Recovery booting in blue at the top of your screen. Release the buttons.
3. You'll now be in Recovery Mode. Use the volume buttons to scroll up and down and the Power button to confirm. It's not a bad idea to wipe the cache partition while you're here, but it is not essential.
4. Scroll down to Wipe data/Factory reset and press Power to confirm.
5. Scroll down to Yes and press Power to confirm.
6. You'll see a notification in yellow at the bottom of the screen to confirm the reset has been completed. Scroll to Reboot system now and hit Power to confirm.
7. Your Galaxy Note 4 will now reboot. Once it has rebooted, you can restore your apps and data.
Let me know if this helped.
Thanks
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Thank you for your help, I already did it for several times but it still not work in my phone, it just display the logo of samsung. What can I do next for this? please help me.. Thank you a lot.
- de
its stuck @ blue thing on the top it neither moves from there nor restrarts
- de
you need to flash it
follow this guide to do it
http://forums.androidcentral.com/ambassa...
Puntuación 1
2 comentarios:
good day! I already downloaded the ODIN and the copy of ROM, but when I plug in my Phone to my PC, the ODIN cannot recognized it. Aside from that when I press and hold home+volume down+power, chinese langauge are displayed and I cannot understand.
- de
I have also a problem on how can I put my phone into download mode becuase it is korean made. I cant understand and locate what button to press to put into silent mode.
- de
It seems that you device has stuck in boot loop. The most common and popular method is hard resetting your device.But it seems that hard resetting has not worked for you.So, try flashing your device after downloading the correct firmware file for your device. Since you have bought the device from Thailand you need to check if the device is using and international firmware or country specific firmware.Here you can have complete guide ++samsungodin.com++
Puntuación 0
Añadir tu respuesta
Rodel Domdom Minoza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 87
Todo El Tiempo: 26,310
