Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
What to buy to replace a damaged Dock Connector?
The dock connector on my iphone 1G was broken. What replacement could I buy from you to replace the connector? Could I actually use the iphone 3G dock connector? Appreciate your response.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
no, you cannot replace 1g dock with 3g. connection is completely different. instead, you need to swap the whole midboard... it is possible to swap just the dock connector, but that is EXTREMELY delicate operation. i strongly recommend you, to buy the assemmbly. you will save a whole !&^@ of problems... unfortunaltely, you cannot buy it on iFixIt eshop, it is unavailable... try later, or search different supplyier.
Fue útil esta respuesta?
Puntuación 1
I have the same problem! I'm buying that piece Dock Connector, but I see that has a battery to one side. and seeing the piece says that does not take the microphone included. I'm in doubt, because I only see a small battery in the connector Dock Connector.this is the part that you say?
Charging Charger port flex ribbon for iphone 2G
Puntuación 0
@Julias
I repair the iphone 1st gen and that model ONLY.
I have used but tested dock connectors, also the assembly which is less messy. but i am not sure if i can supply my email here or not.
@palokiller
It is Not a battery to the side, it is the home button connector and actuator.
Puntuación 0
Añadir tu respuesta
Julius Reyes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,655
