How to repace ignition coil
how to replace my ignition coil 2003 element
Es esta una buena pregunta?
This does not have a single coil instead it has coil packs on top of each spark plug . They are easy to change out usually held down by a bolt and once removed you disconnect the wire harness and pull the boot. Did you get a error code on the OBDII or why are you wanting to change the coil . A misfire will be coded for you and will tell which one needs to be replaced Usually a po300-304 . you will need the fireing order to determine which coil pack to replace. when doing the replace its a good idea to replace the spark plug at the same time . Hope this helps
Fue útil esta respuesta?
there may be a cover over the valves that hides the plugs and coil packs depending on the year of the car
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,172
1 comentario
I Have The Same problem for 2005 Honda Element
- de drealove2
