Saltar al contenido principal
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Preguntas 119 Ver todo
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
No I removed that
- de
My screeen became dim after I upgraded to 10.1
- de
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
- de
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
Puntuación 1
Añadir tu respuesta
Arletta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 1,585
