Saltar al contenido principal
La PlayStation 3 (o comúnmente conocida como la PS3) es la tercera consola de televisión producida por Sony Computer Entertainment, esta es la sucesora de la PlayStation 2. Fue lanzada un 11 de Noviembre de 2006.
Preguntas 782 Ver todo
What causes the power supply to get too hot?
A common thing we see is the power supply in the older model Playstation 3 systems get extremely hot and have to be replaced. One problem is the metal shielding they used and Sony fixed that in the newer models with a plastic casing but the power supplys are not universal.
For an old school electrican out there, what would cause the power supply to heat up that much? If a capacitor gets too hot, they usually pop and you can see the evidence of it so it has to be some other component causing the issue.
The only people that really do the repair on these are in China and the shipping costs get expensive :S
Es esta una buena pregunta?
Puntuación 2
1 comentario
+ Good question! I'd guess it's failing (but not yet failed) capacitors, but I'm not a power supply expert.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The biggest single cause I find for that kind of heat is resistance along the lines of current. A connection becomes slightly loose or a little corroded causing resistance to the flow of current. Resistance to current flow creates heat. Of course I can't say for certain that's the cause of your problem but it is a common source of heat in electrical and electronic systems.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
+ agreed
- de
I would say it's the power regulation section. In taking apart some computer power supplies, I've seen power transistors and voltage regulators that were heavily heatsink'd. They are most likely the culprit, but it could also be a transformer, though at the power the PS3 operates, that's most likely not it.
Puntuación 0
Same problem my ps3 ceche01 power supply gets hot I get error code 80010510 after updating a game on the ps3 (disc) so i launch the disc after updating and i get that code i looked it up and it seems that code is a internal power hardware failure ik how to try and fix but i hope it's nothing else causing that problem too occur
Puntuación 0
Añadir tu respuesta
WiredExtreme estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 43
Todo El Tiempo: 9,157
