Why won't the battery charge when it is put into the charger?
When I put the battery into the charger and wait at least an hour for it to charge before putting it back into the camera, the camera won't turn on.
Es esta una buena pregunta?
If the battery doesn't charge when it is plugged into the charger, it could be a sign that the battery is not inside the device properly. Check to see that the battery is completely in the device, and try to charge it again.
If the battery still does not charge when it is put into the charger, this could be a sign that the battery is malfunctioning. You might have to replace the device's battery, using a Battery Replacement Guide.
Source: Fujifilm X100T Troubleshooting
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,763
