Saltar al contenido principal
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
Why is there a white spot on my screen?
So my father sat repeatedly on purpose on my phone, after that I noticed a white spot on the screen. It's nothing, barely visibile, but every time I see it I feel terrible. Is the screen broken or is it something else?
White spot-> those pixel are always white, on a white screen, those are noticeable because are even whiter.
Here's some photos:
open
Thanks you for your support,
Andrea
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Hi , am too using Moto x4 and I found a dot in the middle of the screen.please tell me is it a problem or what else is it .
- de
A moving round double dots on my screen
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Based on the photos it looks like there may be something pressing against the back of the LCD, causing distortion on the display. It may go away on its own, but even if it doesn't it shouldn't spread to the rest of the screen (I don't think). If you wanted to fix it, you'd have to open it up to try to remove the object pressing against the screen, but you're likely to do more damage than good, since this is fairly minor right now.
If the problem continues check back in with us and we may be able to help you fix the spot =)
Good luck!
Fue útil esta respuesta?
Puntuación 4
8 comentarios:
You're absolutely right, indeed if I try to press vigorously on that spot, the screen distorts itself!
I think I'll follow your suggestion and leave it there for a while!
Thanks for the support,
Andrea
- de
Even I have the same issue... It was on the middle of the screen on my first moto x style... Got it replaced... Then on the second one at the left to corner there is still a slight white spot if we really be able to figure that out...
- de
If you're practice and equipped I'd say to try open it, but tell you what man, after a few weeks I don't even notice it. Just get used(ofc if you're planning to sell it, it's a different story).
- de
Im having same issue on my new moto x style...Will it spreads eventually.. or remains there itself
- de
No, don't worry. After a while you won't even notice it.
- de
Mostrar 3 comentarios más
I had a ASCEND MATE 7 for a while and after about two months got wild white patches on screen, sold it by the way and bought a new one. This new one even had brighter patches from the beginning!
Got this one replaced with MATE 8 by the warranty (yeah, they gave me the MATE 8 instead for whatever the reason!)
I'm now useing it for about 2 and half months and again I got white patches almost in middle and bottom of the screen! What the !&&* !?
I think this is the problem with internal batteries, as they are poor quality and after some time of use the battery's pressing against the back of the LCD ... and the whites appear
Puntuación 1
2 comentarios:
I have got replaced screen dispaly of Samsung J7 2016 but after couple of days at left bottom corner of screen some greenish spots appeared and it is keeps on increasing slowly day by day, can any one has idea of whats the problem?
- de
https://howtofixgadgets.com/how-to-fix-w... this will help you some problem can be solved using pixel fixer and some can't if the whit spot is minor adjust with it and if it's large in size or getting bigger changing screen is the only option.
- de
I have this too. After replacing my Moto X Play screen.
If I apply pressure on the ack it only distorts the screen where the white spots are. Proving Sam Lionheart's theory.
Gonna poke bout and see what's stabbing my screen in the back ;)
Puntuación 0
I had this problem with lg stylo 4. I was keeping a small flat key on the back of the phone under a protective cover. A white spot half inch diameter appeared in the center. I understood what was happening when some people talked about pressure on the phone. When I opened the cover and removed the key the spot disappeared progressively. Initially when the key was put under the phone's protective cover it stayed there (I don't lock my room) and I didn't see the white spot at the time. It appeared a few days later and I failed to relate its occurrence to the key that was pressing on the device from the back.
Puntuación 0
Añadir tu respuesta
Andrew De estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 58
Todo El Tiempo: 97,976
