Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El Dell Precision M4600, un portátil de 15.6 pulgadas que forma parte de las estaciones de trabajo móviles de Dell con potentes capacidades de procesamiento, fue lanzado entre 2011 y 2013 por Dell Computers.
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
Puntuación 2
9 comentarios:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
- de Compartir
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
- de Compartir
I`ll replace my screen and feed you back with the results. Thanks Man
- de Compartir
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
- de Compartir
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
- de Compartir
Mostrar 4 comentarios más
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
Puntuación 0
Añadir tu respuesta
mahmoud eldeep estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 9,350
