Entire screen separated from lcd during battery replacement on iPhone
While beginning the steps for battery replacement on iPhone 5, the screen lifted without the LCD . I was caught off guard to say the least. I was using the suction cup method to lift the screen assembly. I applied slow and constant pressure, when the screen showed signs of lifting, I used the plastic spunger tool, beginning in the lower left corner, to work the screen assembly free. Once it lifted, I confirmed that I was only getting the glass by comparing what was lifting for me to the pictures and video in the iphone 5 battery replacement guide by Andrew Optimus Goldberg. I have been searching both the iFixit site as well as trying different Google searches. I am unable to find any information as to how to proceed or even if I should. I have found nothing that explains how to get the LCD assembly out if it is not attached to the glass. Everything I read tells me that separating the glass from the LCD is an extremely difficult procedure. Since I have been unable to find the necessary information, I put the phone back together and will wait until I'm able to get a response. The information I have found so far would seem to imply that heat is what is the general cause of the glass and the LCD to unbond. The phone is carried in a breast pocket of a shirt for the most part. Occasionally in the hammer pocket on shorts or work pants. Heat during charging has not been a problem. With the phone back together, there don't seem to be any problems with lag or the screen appearance having issues. Any help would be greatly appreciated!
Es esta una buena pregunta?
