Saltar al contenido principal
Lanzada en Japón un 3 de Diciembre de 1994 y luego lanzada más tarde un 9 de Septiembre de 1995 en Norte América. Los modelos que existen son: SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Preguntas 73 Ver todo
Pregunta Cerrada
The optical drive motor on my ps1 is broken
The connector from the optical drive motor to the logic board was somehow broken. The optical drive does not spin at all anymore. Is this a permanent problem or is there any kind of possible fix? Here's a picture of what seems to be the source
http://m.imgur.com/WALaRKi
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
@mr_norm yes that is definitely a good source of any issue. From what limited view we have on your image, it appears that your solder pads are still intact on the board and the contacts on the connector as well. It looks like a solder job should fix this. Since you have the board out and you still have the connector, I'd try to find a place that can solder to get it repaired.
Fue útil esta respuesta?
Puntuación 2
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 198
