Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.2 GHz (Turbo Boost hasta 3.4 GHz), 2.5 GHz (Turbo Boost hasta 3.7 GHz) o 2.8 GHz (Turbo Boost hasta 4.0 GHz) con 6 MB de caché L3 compartida.
Preguntas 774 Ver todo
2015 MacBook Pro A1398 Backlight on screen not working HELP PLEASE
Hi all,
Customer cracked the screen on her A1398 2015 Macbook Pro.
We accidentally ordered the 2013/2014 LCD rather than the 2015... all the connections are the same and it fits perfectly, but when we turn it on, the screen has no display. The screen is working, but the back light is NOT. When you hold a flashlight to the screen, you can see it.
Is there something wrong with the logic board? Or is the 2013/2014 LCD truly not capable of working on the 2015?
Any advice would be greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Anyone? Any advice would be greatly appreciated.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Best advise here is to order the correct part.
Fue útil esta respuesta?
Puntuación 3
My father had the same problem with his Macbook Pro. I fixed it just by turning it on and letting him typ in his password. I believe after that it just fixed itself (it's been a while since it happened). Maybe try changing the brightness of the screen after logging in. I don't know if this will work for your clients Macbook but I hope it does.
Puntuación 0
3 comentarios:
Unfortunately this isn't doing it. We tried that. Thank you for the suggestion.
The real question here is will a 2013/2014 LCD work on a 2015 model
- de
Did you find out?
- de
As far as I can tell they do work but the webcam isn't detected properly. Although the connector fits lvds cable fits etc. It won't play nice with the webcam...
- de
Añadir tu respuesta
KB24 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,464
