Saltar al contenido principal
Esta Apple Cinema Display se caracteriza por el número de modelo M8149 y se lanzó por primera vez en julio de 2000
pink or red screen fix
I have two 20" apple cinema displays and one of them started giving a pink/red tint to the screen image. I was wondering if this is a common problem with a solution that I can repair myself. Any advice would be greatly appreciated! Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Check the number please, is this a A1081?
- de
The number a1038 is the correct numer on my display. It is an older model with the clear acrylic body. It is not the model a1081.
- de
The same is happening to my 22" Cinema Display ( 2000 ). Except it happens intermittently. And the change between normal and orange seemed to be always after the screen was moved.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Reddish color on any monitor/display is a faulty LCD.
Fue útil esta respuesta?
Puntuación 1
When I had this problem on my M8536, it was just because of a faulty cable. Try bending the cable around and see if you can find a sweet spot in which the picture has the appropriate colors.
Puntuación 0
Añadir tu respuesta
legendmacnet estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 1,166
