Why is my steam wand leaking
Hi all I have a Breville dual boiler bes900 and my steam wand just keeps letting steam out when the machine is at temp every thing else is working fine
Es esta una buena pregunta?
Página de dispositivo para Breville Dual Boiler BES900 - BES900XL con guías de reparación y ayuda de resolución de problemas.
I found this link with a fix. Just not sure where to get the Orings.
Comentarios:
This answer is for a Barista model, not a Dual Boiler. There is no stop adjustment and the valve is completely different for the Dual Boiler model.
- de Glenn
Mine is leaking water rather than steam. But maybe a water leak comes from the same root cause? I determined that the plastic handle has worn and the steam control lever now moves beyond the valve's fully closed position to a position which is partially open. So if you back up the lever a few degrees it might stop the flow.
I have yet to figure out if there is a way to replace the plastic lever/handle piece.
Comentarios:
I have the same problem (water / steam leak). My lever is fine. I am just not sure if it’s an o-ring issue or a valve-issue in my case. I have replace o-rings many times with substitutes but the steam wand o-ring, at least one of them, is very difficult to reach/replace from inside the machine. Any suggestions are welcome.
Same issue. It was fine then started dripping water very very slowly, and now it's a regular spitting of steam - not a lot but it's annoying.
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 109
Todo El Tiempo: 5,307
